1977 70hp evinrude top carb problems.. Please help!!
Happyg
OK so I have a 1987 Bayliner in a 70 hp Evinrude on the back of it. I have pulled all the carbs and had them cooked out and I have fire on all three ignition coils and had a compression test ran on all three and its pushing 95 down the line.. But when I pull the plug wire off the plug to check to see if it bogs down like the rest do, there is no change and when I put the boat in the water and run it, it is REALLY bogged down.. I'm at my wits end with this thing and I could really use some help.. I just want to enjoy my first boat and so far I haven't been able too.. Any advice from someone would be much appreciated
interalian
So if you pull off one of the three plug wires you get no change but you say you have spark on all three. Have you tested spark with a wider gap, say 3/8 - 7/16"? If yes, my next step would be to put a timing light on the one that doens't change when you pull the plug wire - you might be losing spark under compression.
flyingscott
Give us a model# Re-check your compression with a different tester because if it's really 95 psi on all 3 that's a big issue.
