I have been reading through sever posts on this type of problem for several weeks now. I think a carborator rebuild is the ticket but would like a second opinion.<br /> I purchased this boat/motor last spring. It ran great until july or so. First it would run fast but with "surges" in power. The surges got worse and now it will hardly get on a plane. I have bought new gas tank/fuel line but that did not help. I disconnected the fuel line from the Carbs and turned it over. Fuel spurts out, but I am not sure if it should be a steady stream or spurting with every turn of the engine. When I first put boat in water and throttle up the boat will have power for a very short time then back to a crawl. Is fuel pump just not getting enough gas to the bowls and when they run out it loses power but there is enought of a stream of gas to keep the motor running slow?<br /> I picked up carb kits /Manual
to do the rebuild but got nervous about it after getting first carb off and started taking apart. <br /> Thanks for your help and suggestions.
