1977 70HP Evinrude "No Power"
DZima
I have been reading through sever posts on this type of problem for several weeks now. I think a carborator rebuild is the ticket but would like a second opinion.<br /> I purchased this boat/motor last spring. It ran great until july or so. First it would run fast but with "surges" in power. The surges got worse and now it will hardly get on a plane. I have bought new gas tank/fuel line but that did not help. I disconnected the fuel line from the Carbs and turned it over. Fuel spurts out, but I am not sure if it should be a steady stream or spurting with every turn of the engine. When I first put boat in water and throttle up the boat will have power for a very short time then back to a crawl. Is fuel pump just not getting enough gas to the bowls and when they run out it loses power but there is enought of a stream of gas to keep the motor running slow?<br /> I picked up carb kits /Manual :confused: to do the rebuild but got nervous about it after getting first carb off and started taking apart. <br /> Thanks for your help and suggestions.
Solittle
Re: 1977 70HP Evinrude "No Power"
DZ - First welcome. Outboard carbs don't really have that much to them and while they may look intimidating at first, they are pretty easy to work on (I am not a "wrench"). You might want to skim through some of the stuff here:<br /><br /> http://www.outboardrepairs.com/carburetors/
Cricket Too
DZ.....Don't get intimidated by those carbs, they are very simple on that motor, and as long as you follow the manual you'll be alright, set those floats right and you'll be O.K., it's only a hunk of metal after all. Good Luck.
tad7777
i think it is the carbs,,almost sure of it,, my 40 h.p. 1970 did the same thing,, the surging is a carb problem,, you can always take it to a repair shop & have them rebuilt,, tad
OBJ
Hi ya' DZ....<br /><br />Hate to be the anti-carb person here (sorta) but...give the engine a once over....compression test, ignition test (spark should jump at least a 7/16inch gap with a hot blue/white spark). You already replaced fuel feed lines. How are the fuel lines inside the engine? Any that are hard and non-pliable?<br /><br />How does it idle? When was the last time you had her tuned up?
DZima
Thanks for the replies. I don't have any way to do a compression test without taking to a mechanic. but the fuel lines between the carbs are a bit hard so I will replace those. Looks like a good spark on each plug.
DZima
Oh, by the way it idles fine and starts immediately.
backdraft
DZima, on the side of the fuel pump there is a nut with a slot in it, inside is a screen for filtering trash out of the fuel. Undo it , pull the screen and while off squeeze the fuel line bulb. Catch the fuel in a jar and look for debris in it. This may be the problem at high speed as it tends to restrict the fuel at that point. nevjb
i agree with you. take the bowl off and look to see if you have any gunk buildup in the bottom. it doesn't take much. the small particle will break loose and stop up or restrict the high speed orfices. at the same time particles may keep reave plates from closing all the way. this may be a cause if it sat a long period of time without using.
by the way you can buy a compression gauge at any autopart store fairly cheap
