1977 70el77 70 hp outboard no forward or reverse
handyjoe
I have a 1977 johnson 70 hp motor that runs great but doent go into gear forward or reverse. i had a guy come out and check it and he said it was a shear pin or that the gears need to get replaced. I calledhime back and he never showed up to fix it. i want to know how to check these things out my self. I am pretty handy and can figure things out but i need some info on the motor. i need a schematic for it and also if it is electric or regular lower end. i found a few lowers end on ebay but i need to know this info first thank.
joe
Randybeall
Re: 1977 70el77 70 hp outboard no forward or reverse
Everybody must have been gone to the lake yesterday. The first thing to check would be the prop hub to see if it has sheared. Take the nut off the prop and see if the rubber in the hub is damaged, first clue might be a nut that is not tight. Second, order a workshop manual. The real thing is best, other brands have questionable information, don't ask how I know.
Dhadley
There is no pin that will cause that. By not returning your call the guy is telling you he doesn't know how to go about fixing it and he's done you a favor.
First - if you start the motor, either on a flush or in the water, is it pumping water?
handyjoe
thank guys i will check about the prop today aso sdoes anyone have schematic for this motor. thanks
this suppose mecahnic said he had 30 year experience and that he would definately be able to get it running so i thought ok is there anyone out there that lives in chicago area that knows about this motor i would like to speak to you thanks
tashasdaddy
joe, first disconnect he shift cable at the motor and try shifting it manually. it could be as simple as a cable. or the shift linkage cames loose. there are not on line manuals. this is the manual you need for that motor
http://www.iboats.com/Johnson_Outbo....393576--**********.152519623--view_id.440609
diagrams and parts list is here. http://shop2.evinrude.com/ext/index.aspx?s1=bf6ad09c53cead335fcfd8a6471c0f7f
the best advice i can give you, is , don't let that guy touch your motor.
Dhadley
Does it pump water?
You'll find a parts breakdown at shop.evinrude.com.
