1977 25hp Evinrude bogging down-Help
tiger5
I have cleaned the carb 3 times and have checked the filter. Motor starts good, but when I give it the gas will not come up to speed, any suggestions.
Thanks, tiger5
Joe Reeves
Re: 1977 25hp Evinrude bogging down-Help
If you have proper compression and spark, either the timer base under the flyheel is sticking, the throttle butterfly is opening too soon, or you're overlooking something within the carburetor. Have you manually cleaned the high speed jet?
tiger5
I took everything apart on the carb and cleaned with carb cleaner and air, I don't think I missed anything. I am getting spark, but I have not checked the compression. I'm not sure about under the flywheel. Thanks, tiger5
jbjennings
If it has that pesky fixed jet, then you have to get it spotlessly clean. You may have to really soak it. Also, when Mr. Reeves said check the spark I believe he meant with a spark tester to see how wide of a gap it would throw a spark across. It should cross at least a 1/4 inch gap to work under compression. what does your compression look like?
good luck,
JBJ
tiger5
Did not get a chance to check compression yesterday, but try to check it today. Don't have a spark checker. Will post later. Thanks, tiger5
outlaw241
not sure if your model has a nozzel gasket but it could be the problem,it a small gasket ithe carb bowl goes up through center of float ,if its bad it wont pick up fuel at high rpm it will suck air above float,very cheap an easy fix
tiger5
I checked the compression and the bottom was 95# and the top was 100#. The checker that I used, I could only tighten by hand so I'm not sure if was seatting good enough? Thanks, tiger5
tashasdaddy
compression with in reason. sounds like a link n sinc is needed.
tiger5
Sorry, don't know what link n sinc means. Thanks, tiger5
