1977 115 Alarm at WOT
dacostadesigns
I have a 77 - 115 which runs fine and can run all day at 3/4 throttle. On last two outings I opened it up (WOT) for a very short instance and the alarm went off. It has a 1yr old water pump and flows great. Looking for advice.
Honorary Supreme Mariner
But the tell tale water does NOT circulate through the block.----It tells you the water pump is working.----It does not indicate proper cooling.
F_R
Pressure relief valve may be stuck shut?
