1976 omc 140 hp. outdrive swap.
furtrapper
I have a 76 deck boat with a 140 hp omc motor, I need to know if I can put a mercursier outdrive on it. and if so what year models will fit it.
Re: 1976 omc 140 hp. outdrive swap.
Ayuh,... The Only way to do that is to remove EVERYTHING OMC on it, glass the transom in, 'n start over...
superbenk
Pretty sure you'll need to add some additional material to the transom to beef it up as well. The Stringer drive doesn't mount to the transom at all so the transom tends to be thinner & weaker (it was never designed to carry the thrust of the outdrive).
Any way you look at it, you're looking at a very involved & expensive project unless you have cheap/easy access to a full Mercruiser setup (still a ton of work though).
furtrapper
I just need to know if I can keep the motor and hook up a mercursier outdrive to it. I will be replacing the transom.
Nope...
