1976 Johnson powerhead swap
crittermo
i have a 76 johnson 35hp short shaft tiller with a bad powerhead (50 & 40 psi compression). i have found a 1978 evinrude 35hp long shaft with remote control. the evinrude has a good (115psi) compression but needs wiring harness and other ignition parts. do you know if i can swap the powerheads and use the electrical parts from the johnson too. thank you
tphoyt
Look up your model numbers and cross reference the parts numbers.
matt167
1976 is the old motor. The new motor came in 1977. If memory serves me.
