1976 Johnson 85HP 85EL76G
dmcneill3
What kind of maintenance do you do to this motor. Is there gearcase oil that you need to add if so where?
The engine does not need oil because it is in the gas mixture correct?
bernd64
Re: 1976 Johnson 85HP 85EL76G
you change the gear oil ones a year it is 90w marine gear lube plugs ones a year and dont let the gas sit in the carbs for to long
kenmyfam
Read up in the "Top Secret Files" for general maintenance.
Water pump impeller is a major maintenance item as well.
Daviet
At the top of the home page of the forum.
kenmyfam
An OEM manual would be a great asset as well.
dmcneill3
Thanks I ordered a manual and just got it today
