1976 Johnson 35hp basic lower unit problem. Cable linkage not loosening
bill_bixby
I'm not sure if I'm even doing this right but I'm trying to remove the lower unit and replace the water pump. I'm stuck here, are these two flathead bolts meant to release the cable? If so, somethings up, the bolts just continue to spin with a little resistance on them. Subsequently, I can only move the lower unit about a quarter inch down right now. Your help is much appreciated, I'm trying to get my boat out on the water.
Thanks!
bill_bixby
The bolt is just spinning (counter clockwise)... Is there a nut on the backside? I can't see back there. Has anyone else had this problem?
Honorary Supreme Mariner
The connecter is / was threaded.---Who knows what has been done.----Turn the connecter and see if there are nuts.
boobie
If you can get the connecter turned around maybe you could hold the connecter somehow and drill the bolt out.
bill_bixby
I sprayed some pb blaster and yanked harder than I wanted but it came out. There is a nut on the back. I'm making a jig to hold the unit and hopefully replacing the pump. Thanks for the help fellas.
bill_bixby
Yeah the bolts on the connector were rusted. One broke when I was dissembling for cleaning.
Also, should there be a gasket on the here? There was no evidence of one...
boobie
I'll be an SOB. In my 50 yrs of working on outboards I have never seen that as it's a first !!!
bill_bixby
Well it was an SOB to get out haha. Is there supposed to be a gasket between the lower unit, and "Lower lower" unit? There was no evidence of one, but I would think there would have to be? Thanks for your help.
lindy46
Yeah, threads in the coupler were stripped and someone put longer bolts with nuts on the backside. Not sure how they tightened both of them. I have used a bolt on the back of the lower coupler with the lower unit off. But the upper coupler threads were good. Those couplers are expensive if bought new. Easy to strip the threads if you overtighten the bolts.
bill_bixby
I kind of figured that's what was going on with the coupler. I really haven't come up with a good solution either... I thought of putting some jb weld in the coupler and connecting the rod, but that's no good for next time...
Last night I tried to put the unit back on and it was getting to about an inch left and stopping. I thought it may be the water tube having a tight fit with the new rubber sleeve in it, so I tried it without it in just to see and still it wouldn't mate.
At one point I was close enough to connect the shift rods and tightened the bolts, and shifted to see if it would help me, but the rod just came out of the coupler. That's when I realized I'm probably going to have to find a better solution for the coupler. Figured I'd sleep on it.
Now this morning I try again fresh and I can't even get the shaft to thread in up there.... Haha the joys of old boat motors!?
So I basically have two problems now. What to do with the coupler, and actually getting the shaft to go all the way up in there... Any advice would be appreciated, I am a novice, thank's guys.
lindy46
You may have to turn the prop (gearcase in gear) to get the splines on the upper driveshaft to mesh with the crank. Make sure the water tube is in place in the upper grommet and maneuver it into the lower grommet in the water pump housing while turning the prop until the lower unit slides all the way up. Two people helps. Shift the motor into forward and keep the gearcase in reverse (shift rod down). Then you can connect the shift rod as the last step once the lower is in place.
The notches on the rods have to line up with the holes in the coupler before bolts are put in.------If on a budget you make a piece of 5/16" plate to go behind it with 2 holes threaded..
bill_bixby
Sounds like a good plan. I'm going to have to get a second hand over here. Thanks!
bill_bixby
I may end up doing that. It is not easy having to fit two wrenches in there sideways... I'll keep you guys updated. thanks for the help!
