I have a 1976 Johnson 25 that I just got running recently. It didn't have spark before so I swapped all the electrical with electrical from a power-head with great spark.
It will start right up 1st or second pull with the choke and after it idles for 10-20 seconds (or until a little warm) I can turn the choke off and it will stay idling. (at least 5 minutes it was idling).
If I put it in gear the rpm's drop pretty low and it will stay running but I can't give it any throttle or it dies out.
I'm new to boat motors, so any help would be appreciated. I haven't cleaned the carb yet, but if I do are their any passage ways I should make sure are extra clean?
Here is a picture of my throttle timing in neutral without any throttle. I see the two timing lines but I'm not sure what they are supposed to line up with..
Thanks,
Ryan
Thanks,
Ryan
