JOHN BLUESY
Thread starter- Joined
- Jan 23, 2021
- 9
I just bought this 1976 10625H 9.9 long shaft evinrude and got it running but no water circulation so I replaced the water pump and it does not work, The impeller is turning for sure, I put the leg in a bucket of water almost up to the pump so every hole was covered and spun it with a drill but it just does not pump water and neither does the old pump, There are no blockages i can pour water down through the leg and it comes out everywhere it should. There is a gap under the wear plate but I assume its to allow water to be sucked in to the pump. I have replaced pumps and impellers before without a problem but this one has me beat There is a flat spot on the shaft for a keyway and a small pin that I locate with grease. I have held the punp housing up about 10mm and I can see the impeller spinning but the pump wont suck or pump, I even put water in the pump from the outlet but no joy. Any clues anyone, it got me buggered
