welp.. I suppose you know the vent's open now...not all carb sprays are rubber and plastic friendly, be careful what you expose those parts to..since you're familiar with Leroy's Ramblings on this model...if you'll go to his site and refer to the parts diagram for the carb...#21..Boss or Nozzle gasket..is yours in place?..#27 Orfice Plug or main jet...you can clean it in place but you must be sure it is absolutely clean and spotless...#35..core plug...did you remove this and clean the 3 or 4 holes that exit that chamber?..they are small and enter the carb throat behind the throttle butterfly...#15..Idle Mixture Needle..as Oldboat suggested...have you removed it and made certain that passageway is clean as a whistle?...#22..Float..installed with float arm tab pointing towards the carb body, not the float bowl, and the float is parallel with the float bowl flange on the carb body?...if you are absolutely certain all is correct..all I can suggest is you get another float, a cork one, and try that instead...other than buying a used carb and rebuilding it, I don't know of anything else to suggest
