I have to convert my 76 evinrude 35 from electric to manual. Do I remove the alternator coils or just disconnect them? I have a new flywheel and recoil starter etc. Looking at the service manual it looks like the alternator and stator are missing.
Yes it does have points and condenser. I will remove the charging coils as I have to pull the flywheel. My next question is what do I do with the remote start switch. Can I replace it with a on off switch as there is no need for one with start position and I will have to relocate it to the rear of the boat. I will eliminate the electric choke for manual operation. So the wiring harness is down to the two blue/ blue white stripe wires going to the points and condensers from the switch...is that all I need to get it to run on the electrical side?
Hardwater Fisherman I will have to change driver coil?
