Jessie0007
Thread starter- Joined
- Oct 29, 2005
- 3
Hello, I have a 1976 85hp Johnson 4v seahorse outboard and have a problem with a miss in the engine. It really seems to only do it at idle or 900-1000rpm, that is the lowest the engine idles? No, idle adjustment screws on the carbs? I am not sure if it will do it at higher rpms because I have never had this motor in the water. Anyhow, I have cleaned both carbs, tried different plugs, the spark seems fine, jumps over 1/4" without any problems there. Only other problem is that all the plugs are wet. I dont know if this is the problem with the miss in the engine or how to adjust the fuel to the plugs. Usually the engine just misses and picks back up again but sometime it will quit altogether. Only other noticeable defect was a small crack in one of the ignition coils but I filled that up with epoxy, does not seem to effect the output of spark but seeing that all my plugs are really wet/oily I am assuming that is not the problem. Also, I am not sure if the engine is getting up to full operating tempeture, I can touch the heads and they are warm but I can keep my hand there after running for 10 minutes or so. Any help on this matter would be appreciated! <br /><br />Thanks, <br />Jessie00721
