FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
i have recently purchased a small boat with a 70 hp evinrude and cannot get to more then 2000 rpm while underload. it will rev great while not under load, but while running in lake can only go about 10mph. any ideas where to start?
a new-to-me engine I would
1. check compression
2. clean/rebuild carbs
3. change plugs using the correct reccomended ones
4. change lower unit fluid
5. check spark
6. change water pump
7. decarb
most likely you have a gummed up carb if it has set for any amount of time
ok will do thank you. i have replaced plugs, and checked lower unit fluids. the motor has lots of power, just wont go over 2000 rpm. is there some kind of restrictor or rev limiter that im not finding?
i have a 1975 70 hp evinrude and being that old the coils develop cracks and start arcing so my guess is you have a bad coil, had same issue with 50 johnson, running on 1 cylinder wouldn't go over 7 mph. An easy way to check if its arcing would be to leave the hood off and fire it up at night and look for the pretty blue light.
theres no doubt in my mind the high flow jets are clogged up... i would either try to do a decarb, which might be too late, or definetly rebuild the carbs....
