1976 40hp johnson will not start
cb4hunter
my 76 johnson will not start i put gas in with the spark plugs then it will start for a second or if i put gas in the card it also starts for a second what could i do.
Daviet
Re: 1976 40hp johnson will not start
Sounds like you have a fuel delivery problem. Does the primer bulb pump up firm? Is fuel getting to the carb? How long since the carb has been serviced?
cb4hunter
the primer bulb does pump up firm i do not know when the carb was service.
Daviet
Try squirting fuel mixture into the carb, if the engine starts and runs, it's time to overhaul the carb.
