1976 (200) 20hp electronic choke?
sahendo
1976 (200) 20 hp model #1200506E, serial #441xxxx.
I was wondering if anyone had a picture of the linkage and solenoid, so I can see how it operates. The diagrams I found only show manual choke. My motor has the solenoid but no linkage to the choke.
I guess I'm gonna try to make my own if I can get a idea of what I need.
GA_Boater
You you have the slug that fits inside the choke solenoid? Item #48.
sahendo
No Title
Yes I have the plug and there's a plastic piece that it attaches to on the carb, maybe #49 on the diagram hard to tell from the diagram, but it looks like there's a piece broken off.
GA_Boater
It does look broken. A whole one looks like this with the part number. Replacements are still available;
Do you still have the manual choke?
sahendo
Yes the manual choke still works, Just trying to get the electric choke working because of where the control box with the key switch is located it's hard to operate both at the same time. And I'm one of those guys who likes everything to work!
sahendo
I've been looking for a diagram or a good picture.
sahendo
Where did you find the diagram? When I look up my model # it only shows the manual choke.
sahendo
I found it, gonna see if I can scrounge up the parts, they say they are NLA
sahendo
Ok I can get the choke lever part# 65108, but I cannot find the the linkage part# 65107. Does anyone have a picture of it on the carb? I wanna see how it actually operates.
sahendo
Ordered the choke lever, part# 65108. I need the linkage part# 65107. If anyone knows where I can get one or has a picture of it so I can try to fabricate one, let me know
I would simply install an electric primer from a Johnson / Evinrude.----------Very good item and used for 30 years on many electric start motors from 10 hp to 300 hp.-------Your local dealer may have used ones.
sahendo
I would still like to see an actual picture of the setup on someone's motor. Somebody has to still have one of these motors with the electric choke setup on it. Anybody?
