OptsyEagle
- Sep 13, 2006
- 1,367
I have a new to me 15Hp Evinrude (1976) and noticed that the plate, underneath the flywheel, that the two little nuts screw to, that are used to synchronize the roller cam from the carbs throttle, is loose.
The two little nuts are still tight but the plate that they screw to just rotates on its own, irrespective of whether the throttle is turned or not. It seems to me that it should not do this and I am wondering if there is some way to tighten up this plate.
A secondary question is when it is tighened I am going to want to sync the carb and will need to loosen the two little nuts. They sit underneath the flywheel in such a way that my wrenches don't fit underneath the flywheel. How do you guys tighten and loosen those two little nuts? What tool do you use?
