1976 115hp merc gas problem
Roachb
I hooked up a used engine I got and am having problems with the gas leaking at the connection point...I can hear air when i squeze the gas bulb pump..I took the some pics of it....It appears find and looks like nothing missing what going on here? also I noticed some of the wireing look old and coroded fuel pump wire....What kind should I use to replace it thanks
Chris1956
Honorary Supreme Mariner
Re: 1976 115hp merc gas problem
Sounds like you could use a new Merc quick connect. If gas leaks out, air will leak in, which is bad. Usually the motor wiring harness on those old motors is about shot. Replacements are avail on the web.
Roachb
It seems to be just a few of the wire on the bottom..All the wires on the top can bend and move freely...but if i bend one on the bottom the plastic coating on the wire breaks right off!, and exposes the metal wiring:eek: I cant see any type of identification on the wires and dont really want to buy a whole new harness when i just have to replace a few of them...any ideas??
Milduff
If your "handy" you can splice and repair wires. I would suggest using the same color code as existing for possible later troubleshooting. Make sure you use shrink tube to seal splices. On those old motors the wiring tends to NOT take solder very well, make sure you use a good paste (cleaner) before attempting to solder.
