1976 115 HP Johnson outboard motor
clueless
Refurbishing a boat. We took it out last weekend and rode for 2-3 hours. Now when I try to start it in the water, it starts, but shuts off when put into gear. Runs in gear in the front yard, but spits, sputters and backfires, then winds out on its own. Changed spark plugs, cleaned carb, cleaned fuel filter. Using 50/1 ratio gas to oil. Sounds like timing is off. I know it's 24 degrees TDC, but don't know how to adjust. Any ideas?
JB
Re: 1976 115 HP Johnson outboard motor
Timing is probably okay. Sounds like fuel starvation to me, Clueless. "winds out on its own" is classical running out of fuel with no load, as is spitting and coughing. Dies when placed under load is another classic symptom.<br /><br />Check fuel tank, pickup, hoses, primer bulb and fuel pump.<br /><br />Good luck.<br />Red sky at night. . . <br />JB
clueless
Hey, thanks for the quick reply and info,brand new gas tank, new bulb and gas line, replaced all gas hoses, vacumn hoses, if there was a hose i replaced it, fuel pump dont know, dont know where it is, can you help, not trying to sound ignorant but I know atvs and dirt bikes, first outbaord ever messed with. I also put a inline fuel filter on. thanks again hope to here from you soon. clueless
Down South
Hi Clueless,<br />Will it run if you maintain pressure on the primer bulb, if not it sounds to me that you have an ignition problem. I'd check the plugs to make sure that they are all firing. you may have bad plug wires, coils, ect...<br />
