1975 V4 85hp johnson
sbassman
I bought a cherry 1975 Newman charger tri hull with a 1975 V4 85hp Johnson on it last august. This thing ran great only used for a few hours a week tubing and joyriding until late September. I put it away in October I ran some stabil through the gas and fogged the engine. I have taken it out twice this year and when I went to take off from the bouys (motor was idleing fine before take-off). when I pushed the throttle down it wanted to spit and sputter. Then anything over 1/2 throttle it would just spit and die.. So I came home and replaced all the spark plugs. Took it out today and it ran great. Then I stopped and I felt some vibration(spitting and sputtering). Then I went to take off and it was lazy getting out of the hole then ran great for about another 10 minutes wide open. Swam for a bit then the same thing happened as I first mentioned idled to the ramp to bring it home. Idled poorly on the drive in. I put fresh gas in this year before the first trip out. After today was all said and done I ran about 3-4 gallons of fresh gas through it... Could I need to rebuild the carbs???? I just don't get it. Ran great last year and poor this year. It sat for 7 months roughly. All fuel lines seem fine and everything is sat like last year boat was stored indoors.
Watermann
Re: 1975 V4 85hp johnson
Could be a fuel delivery problem, check from the tank out, vent, fuel hose, connections and fuel filter. If it all checks out move on to fuel pump, carb supply hoses and finally carbs. Remember she's 38 years old now and may need some extra love & money to keep her running fine.
My 1977 has had everything listed above either replaced or rebuilt.
