tompowers85
Thread starter- Joined
- Nov 28, 2004
- 125
I have a merc 8500 that i got last year. I had trouble last summer so i spent the winter trying to fix the problem. I rebuilt both carbs I have ajusted the float levels and tested the compression, but i cannot get any power out of the motor. I went out today and for some reason when i prime the bulb the carbs are still leaking, they are pooring gas, and there is air getting in the lines. I have replaced all of the fuel lines. I am going to go over them all again. The bulb looses pessure after about 1-2 minutes. Will the air in the lines push more fuel pass the floats and cause the engine to flood and loose all the power? I only went 5-10 mph. I want to make sure that will cause that kind of decrease in power.
