1975 mercruiser 165 starting issue
Rumley
My engine won’t start. Just clicks. Batteries are good. I read to jump starter solenoid but I’m not sure which 2 wires to jump. Including a pic of what I think is the solenoid. Any help much appreciated.
Start with cleaning every battery cable terminal connection, both positive and negative
alldodge
Cross these two shown should energize the relay and the starter should crank the motor. If this does not happen, you can jump across the larger terminals on each side which by passes the solenoid. Doing it this way will pull a lot more current, so if done use large cables
Rumley
So cross the 2 with the key in the run position with the 2 blue arrows?
if that doesn’t work a booster pack on both of the large posts with key on?
thanks
alldodge
Yes
No
If that does not work use jumper cables to connect between the two large post to bypass it
Use the biggest screw driver you own when jumping the two large contacts, or a short section of 2 gauge cable
However start with cleaning all the connections to shiny clean metal
