1975 meecury 65hp outboard motor
Josh9187
Question i want to know if this is normal have no experience with boat motor so I replaced impeller now I got 2 good streams one is from the hose to pee which looks like it on the clinder side and the other is on the left side of motor by the exhaust where i guess that goes down lower gear whit of the gasket to top and shoot down is this how it is suppose to run it was on muffs only 1 min
Josh9187
Water xome from the left side and from right-side why is that normal
Ed27518
can you circle where the two streams are coming from in the pictures? Also, in general there should only be one "stream", at least to my knowledge.
Josh9187
Thanks according to a marine mechanic I guess he said the pervious owner must have made that other one for better visibility of the cooling water coming out
Honorary Supreme Mariner
Some of these may have had a water cooled fuel pump.----Perhaps that was disconnected / bypassed ?
