1975 Jonson Lower Drive shaft bearing
richfo
Have a 1975 85hp Johnson when changing gear oil made a bonehead mistake by taking out the allen screw for the lower driveshaft bearing. When I screwed it back in went all the in and fluild statred coming out backed it out and fluid still comes out. Is there a way to correct this without taking lower unit apart and did the drive shaft bearing slip down or turn so the screw will not go into it? Thnaks
