1976evinrude
Thread starter- Joined
- Apr 11, 2011
- 77
Hey guys just have a couple of questions on the water and around it. To start when I removed the water pump housing the impeller was stuck on the shaft so i had to cut it off and chisel it, this wasnt a big deal but my questions were when installing the new impeller what ways do the fins go inside the housing, how do I install it so that the fins end up the right way? My other two questions were on the gear case diagram for this engine it shows that there are guides that attach to the water pump housing that go onto the two copper tubes and I couldnt find them anywhere. Are they needed or should I buy them? My last question was next to the water pump housing there is another housing with the shift rod going into , knowing my I got curious and decided to pop the 4 bolts off that one and see whats inside but when the casing popped off oil came out and spilled over is this the oil from the lower gear case? howd it get that high when the upper fill plug is below it? Im guessing I also have to replace that seal now since I opened it up.
This might be hard to understand but It would help clear up alot of parts im confused about in the lower unit!
Thanks!!
Thanks!!
