gnarbrah
- Sep 20, 2007
- 140
Hello all - now that I think my little 6HP will be back in running shape soon I figured I'd check the lower unit oil. I had noticed a drop or two under the motor (stored upright) coming from the back of the prop. I pulled the drain screws and a solid cup of water came out before the black sludge. I went ahead and pumped it full of fresh gear lube and sure enough it's dripping from the prop shaft seal again without even running the motor. I've contemplated rigging up a pressure tester but I'm fairly certain of what I'll learn. That being the case I'm going to give a go at replacing the seals (might as well do the impeller while I'm in there). Question - Is it a tough job? I'm planning on just replacing part numbers 314167, 313282 and both drain plug washers. Sound right or should I do some other stuff while I'm there?
Thanks!
Thanks!
