I have a 75esl50b Johnson with original control and I have been having problems with the shift lever inside the control box. I have broke 2 so far. The plastic teeth are garbage but anywho they broke due to the cable. I fixed the cable it works very well now but the problem I'm having is the shift lever will slip out of place and by that I mean if you go full throttle reverse it will slip and when you put it back in neutral it will shift into forward
