1975 Johnson 50 HP control lever shifting problem
Raghue
I have a 75esl50b Johnson with original control and I have been having problems with the shift lever inside the control box. I have broke 2 so far. The plastic teeth are garbage but anywho they broke due to the cable. I fixed the cable it works very well now but the problem I'm having is the shift lever will slip out of place and by that I mean if you go full throttle reverse it will slip and when you put it back in neutral it will shift into forward
Raghue
When it slips reverse is neutral and neutral is forward. Will the throttle friction adjustment help to prevent this?
Honorary Supreme Mariner
One question first.-----Are you doing the shifting with the motor not running ?-----Motor must be running or prop must be turned when shifting.
