airman1094
Thread starter- Joined
- Mar 30, 2013
- 108
Hi all! I just acquired a 1975 Johnson 115 that hasn't been run in an unknown number of years! I know I'm beating a dead horse in posting this thread(since there are plenty related to reviving outboards), however, I just wanted any input related to this particular outboard. The motor spent the last few years under a tarp on a test stand. I've inspected the wires on the outboard, lubed up the crank (via the bypass covers and through the reed valves), inspected the lower end and checked the impeller and am in the process of replacing those pesky little prop shaft oil seals
! I did give her a spin with the starter hooked up to my car battery, and this is where my problem begins...the starter won't turn over the engine with the spark plugs in! The engine isn't flooded as I wasn't giving any fuel! When the plugs are out she spins smoothly! I disassembled the starter, cleaned and checked, then put it back on, checked the solenoid, and re powered and same result! I am using the old batt wires that were exposed to the elements...they seem to jump and heat up when I engage the starter! I'm guessing I need new cables! I've also polished and tightened all ground points and power points to rule out other connections! Did I miss something? Any other steps I need to do before I crank it up? Thanks!
