1975 Evinrude 75hp 3 cyl fast idle
twobubs
Need some help with this one: When timing is set a TDC and throttle plates are completely closed (choke all the way open), engine speed is around 1300-1400 rpm. Only way I can get engine to slow down is to retard change timing to AFTER TDC -- engine necessarily stalls around 700 rpm. Checked float level and needle - all okay, there are no jet adjustments that I can find. Engine runs well at high speed. Could use some suggestions here, please...
