1975 Eldocraft 15B transom and deck rebuild
ezmobee
No I didn't know that. This is the first time I have ever done any "glass work".
I didn't either when I did some stuff on my old boat. Sealed my outer transom board with just some poly from Lowes. It cracked in short order. You need to add some chopped-strand mat (CSM) with it for it to be effective. I believe you can use it for laminating but again, use CSM in the laminate.
Woodonglass
Read the link again it tells you exactly how to build the transom you glue the two pieces together first then apply the resin and cam send me a PM with your phone number and I'll be happy to call and walk you through the entire process
