newboatfella
Thread starter- Joined
- Sep 23, 2009
- 5
hello all, Ive taken apart thermo housing cover and plate to remove and clean and test vernitherm, valves and springs. My Johnson service manual says to place vernitherm spring, vernitherm valve and relief valve spring under thermohousing plate and secure with screws. Then place vernitherm element and pin along with the relief valve in thermo housing cover and secure. My problem is this is not the way it came apart. the vernitherm spring, valve and the relief spring and valve were installed behind the thermo housing plate. Only the vernitherm element and its pin were installed in the cover. A cutaway view on page 6-2 agrees withe way it came apart, as far as i can see. The engine runs ok on muffs but overheat buzzer went off about 2 minutes at idle in test tank. Really confused on this, can anyone help me.
