1975 40hp Info needed
TAC_Double
Hello,
Just picked up this pontoon with a 75 40hp evinrude, model 40555C. I am going to be freshing up this motor, been sitting for a while. I have ordered the factory manual to aid in this. But in the mean time can anyone give me a little info on this motor?
I am looking for the following info,
1. Recommended spark plugs and plug gap.
2. Recommened gear fluid for the bottom end.
Thanks for any help you can supply!
OBJ
Re: 1975 40hp Info needed
Welcom Tac!
Spark plug is a Champion UL81C set at .030.
Gear lube, lot of the stuff out there. Just make sure it's for mechanical shifts and not electric. Your local J/Rude dealer would probably recommend Hi-Vis or Ultra Hi-Vis.
Fuel mix is 50:1....16oz oil to 6 gal of gas. Make sure the oil is TCW-3 rated.
You may also consider replaceing the water pump impeller (or get a pump kit and replace the whole thing) and t-stat.
TAC_Double
OBJ,
Thanks for the fast response. That was the info I needed. Now I have another question, how hard is it to access the impeller? I have looked at the parts sheets and it does not look like a terrible job, but i have never done it before.
