1975 15hp starting procedure
redcat
Hi all,
Can anyone help me with the cold starting procedure for this motor?
Rick.
Re: 1975 15hp starting procedure
Pump the primer bulb
Neutral gear
Full throttle (throttle will only go so far in neutral)
Full choke
pull the rope
At first indication of ignition. put choke to half choke
When it starts, push choke all the way in.
That's what works for me. (79 - 9.9 & 82 - 15) Rick.
cbavier
Pump Primer bulb enough to get gas to the engine.
Place shift lever in Nuetral
Pull out choke.
Pull starter cord or turn ignition switch to start.
Make sure your oil to fuel mixture is correct.
Not much help with out any details.
