1975 15 hp help?
Frank Acampora
Re: 1975 15 hp help?
The pinion is white nylon and still available. You may be able to get it at a Mercury dealer and they may have used the same part for later Force engines.
The plastic part in the photo is one part of two. there should also be a stepped tapered piece so the throttle bar can be adjusted.
If you can'find the pinion gear locally, try franzmarine@aol.com. He should also have the plastic support.
wlldraper
Thanks for the help. Franz Marine was on top of it even on Sunday. The part shipped this morning. Thanks again
