Parkwoodplace
Thread starter- Joined
- Feb 17, 2014
- 12
Hello All,
I own a 1974 Starcraft Supersport that was given to me by my father-in-law about 10 years ago- after the barn that it had been stored in for 15 years finally collapsed on top of it. It came out relatively unscathed- a broken windshield and a broken transom mount on the 65 Evinrude. I found a used transom mount, changed the water pump and spark plugs. It has run like a top ever since. The hull is in good shape with no obvious leaks. Over the last 10 years the seats and floor have deteriorated to the point where a complete re-fit of the interior is in order. I have been a member of this forum for the past year and have learned many useful things. I have completed the tear-down and would now appreciate some advice on how to fasten the new floor to the existing aluminium stringers. My question is this: The holes drilled in the stringers for the original rivets are not drilled consistently in the centre of the stringer, so it will be hard to accurately drill through the plywood to re-use the original rivet hole. Should I drill new holes through the new plywood floor and into the stringer? Also- the original floor was 1/2". Should I consider going up to 5/8" or 3/4"?
