Thistledew
Thread starter- Joined
- Jun 16, 2016
- 17
Hello! I have a Mercury 850 that just started giving me some problems. I recently put on a new fuel primer bulb and a complete wiring harness. The motor has been running good this year so far until I decided to pull my kids behind in a tube. They like to go slow(young kids) so the boat never gets on plane and plows a lot of water. When doing this the boat will bog down and lose all power and stall like its starving for fuel after a few minutes. If I pump the primer bulb it will start back up and be good for a bit longer. The weird part is that if I disconnect the tow tube it will go wide open all around the lake no problem. Does anybody have an idea what might be going on? I am thinking maybe it's sucking air around the new primer bulb. My other thought and worry though is that it may be overheating. It pees water but maybe not all the blades are intact. Would overheat cause this issue too? Im mechanical but new to outboard motors! Just looking for some ideas to go along with mine. Thanks for your input!!
