1974 merc 40 hp dies
woodboatnut
Hi Everyone,
A neighbor has a 1974 Merc 40 hp that was sitting for 2 years. We got it running, and it ran for 1 short ride. On the 2nd ride I had to squeeze the primer bulb to keep it running to get back to the dock. I put in a new fuel pump kit, and that solved the problem of having to squeeze the primer bulb to keep it running, but now it dies after running a few minutes, and you have to choke it to get it running again, and use the fast idle lever to keep it going, and then it dies like it runs out of gas. It has fresh gas that was put in an empty tank. I'm thinking carb problems from sitting? Any help would be appreciated.
Faztbullet
Re: 1974 merc 40 hp dies
Since its been setting I would rebuild the carb anyway, check all fuel connections for air leaks and recheck that you have the correct fuel pump diaphram kit as the gaskets are different between a 55278A1, A4 & A5 and you need the A1 kit.
woodboatnut
Is the55278A1 kit the same as kit 21-30430A 3 kit that I installed? Thanks.
