1974 Johnson model 6r74c
samus_69
serial number c49995
Hi I have this motor and it leaks gear oil out the exhaust. My boss bought the prop seals but those are not the ones leaking. Inside my gear case was a bunch of water like all the old ones are. but I cant seem to get the leg off like normal to inspect the other seal and replace it. i took the tiny snap ring off the driveshaft and removed all the bolts from the leg but it only moves down about 1/3 inch then stops at the woodruff key slot. how do i remove the leg.? diagrams arnt helping
