cxturboboost
Thread starter- Joined
- Jun 4, 2016
- 6
Hello,
I have a 1974 Johnson 85 HP. It struggles due to the weight of the bass boat. I'm somewhat confused as the reading indicates that some people can just change out carbs to the 115 / 135 and exhaust. I'm thinking maybe there is a year cut off that this is applicable? Also is 73-77 lower units appear to be compatible based on the reading I've done to swap over a 115/135 power head?
Any advise appreciated to give this old girl a little more umph.... Carbs cleaned, stator and power pack have been replaced and the motor runs as it should both idle and full load, just heavy boat. Compression is good in motor. Boat just really needed the 115 or 135 from the factory. I rebuilt the transom and made it thicker which also added weight.
Potentially this upgrade is not worth my time? Boat runs about 40.
Thank you in advance for any help!
Pete
Pete
