stangelandfamily
Thread starter- Joined
- Jun 25, 2012
- 3
I recently purchased a motor of the specs listed in the title.
After hooking the electronics and the throttle up and attempting to start the motor, I turned the key and nothing happened. All wires, including the key controls were tested and work except for the starter wire (connected to the lower part of the selenoid). I attempted to arc start the motor by placing a wrench on the upper and lower cables (above and below the selenoid) and it started up. Could this be a selenoid issue since it is not allowing power to the lower cable (which goes to the starter?)
