1974 Evinrude 40 HP impeller change model 40455S
buddhapi
so, I pulled the drive shaft out of the lower unit to change the impeller, and now I can't get the shaft to go back down into the pinion gear. any suggestions?
boobie
Re: 1974 Evinrude 40 HP impeller change model 40455S
Try putting the l/u in different positions while trying to put the d/s in.
F_R
Honorary Supreme Mariner
The pinion gear is captive in that lower unit, and there is no reason the shaft shouldn't just slide right in. Maybe the splines aren't aligning. Rotate it a bit while sliding it in. Or if all else fails, put it in gear to hold the pinion from rotating while you rotate the shaft in.
