1974 6hp Johnson
scottchristie
Hello, My 6 HP Johnson revs decent under no load,but when in gear especially forward, it does not come up much in revs, basically bogging down, but not really missing, just no power. I have changed plugs and cleaned up the points (filed), the gap is.020. No change. When idling, which is a little rough, it does at times seem to run better for a split second and the go back to OK running. Would you start with ignition: points condenser maybe coils or fuel delivery: rebuild carb, fuel pump etc.? Any advice would be greatly appreciated. Thank You Scott
F_R
I would start with a compression test to see if it is fixable. If it passes that, proceed with a check to see if it is running on both cylinders (probably isn't). Disconnect and ground one spark plug wire and see how it runs. Then do the same with the other plug wire. Chances are it won't make any difference with one grounded, but won't run at all with the other one grounded. That is the good one. Now find out what's wrong with the bad one. Don't ignore the possibility it may just be a bad spark plug.
Classic symptoms of a motor running on one cylinder.---Check the intensity of the spark.---Force the coils / system to jump across a gap of 1/4" or more and does it do that , yes or no.---Common for the the head gasket to fail on these as well.---Do a compression test on it.---That motor will rev up in neutral running on one cylinder and that test is a waste of time.
scottchristie
I have changed mult. plugs. I'll do a compr. test and spark check tonight. If it's ignition, would you replace just points and condenser or also the coil.Should both sides be replaced with a tune-up? Thank You Scott
???---You test and trouble shoot.---Replace only defective parts.---Remove coil and inspect the bottom of the coil that is not firing properly.----They have been known to burn through the insulation and spark jumps to the magneto plate instead of going to the sparkplug.----Testing / inspection / trouble shooting is the way to move forward.
