scottchristie
Thread starter- Joined
- Jun 1, 2015
- 2
Hello, My 6 HP Johnson revs decent under no load,but when in gear especially forward, it does not come up much in revs, basically bogging down, but not really missing, just no power. I have changed plugs and cleaned up the points (filed), the gap is.020. No change. When idling, which is a little rough, it does at times seem to run better for a split second and the go back to OK running. Would you start with ignition: points condenser maybe coils or fuel delivery: rebuild carb, fuel pump etc.? Any advice would be greatly appreciated. Thank You Scott
