cheapthrills
Thread starter- Joined
- Dec 8, 2008
- 12
First, the questions:
1) Does this motor have a thermostat and poppet valve?
2) If so, where are they located? (Seloc manual does not show)
3) I am not getting water out of pee hole. Any other causes to check?
4) Can overheating cause it to miss?
History:
Bought 77 Sportcraft w/ 1974 Merc 3 cyl 65 HP in ATL in June, rebuilt carbs, had it tuned and ran it all summer w/ no problems. Water coming out of pee hole in lake and w/muffs. Moved to Fla in August.
Ran boat for about 4 - 5 hours, idle to cruising speed, just putting around in Black Creek, which is brackish. On way back to boat ramp, ran over a 4 X 4. About 10 minutes later, boat started to miss badly. Noticed fuel leak by bulb in fuel line. Tightened up, but kept seeping. Don't know if fuel bulb caused miss or if motor overheated and started missing. Made it back to ramp and towed boat home. Put muffs on it to flush, but no water out of the pee hole. Pulled lower unit this weekend-impeller looked fine, but replaced entire water pump assy. Put it back together and put muffs on it. Still no water out of pee hole. What else should I check?
History:
