1974 225 IMP R outdrive oil plug gaskets
rebars1
Do the oil fill/vent plugs (screw) use gaskets or "o" rings for sealing? I was unable to find it in the service manual. The ones on the screws now are so flattened that it is hard to tell.
thumpar
They should be flat paper/fiber gaskets. It is recommended to change them whenever removed. NAPA carries them usually.
