1974 115etl74b johnson
tdoucette
i need some help on this i am having troublen with my stator melting it is pushing out 16 volts of current at all times is this good or what is my problem why does this keep happening please help
ezeke
Re: 1974 115etl74b johnson
The motors in the series have unregulated rectifiers that cannot be used with no maintenance car batteries, and don't even work well with smaller starting batteries.
You can use a large deep cycle dual purpose battery to regulate, but if there is a current problem, replace the rectifier when you replace the battery.
When rectifiers go bad, they often heat up enough to fuse the wiring and allow the battery voltage to reach the ignition sytem - that can fry the whole system.
Rectifiers can be killed in a nanosecond by reversing the battery cables, or by anything that allows voltage to flow back to them in the wrong direction, such as a bad ignition switch. You can kill them with loose connections on the battery, or with a battery switch of the wrong type.
tdoucette
this will be my second stator it has started to leak already
tdoucette
so my best bet would be to replace my rectifier someone told me to get a voltage regulater off a newer model that had it in the place of the water pass through plate will this work also
ezeke
Do you have a power tilt and trim?
tdoucette
yes i do i have a cmc power tilt and trim
