1974 115 switch box question
richardlee
I had my motor running well. I took it to a shop to pull the motor so I could replace transom. Then had them remount the motor. It would not start. No spark to plugs. I did a little testing but had to lay everything aside for several months. This week I started working on it and began testing. I had power on the red and white wires on the switch box coming from the wiring harness. On the distributor side, I had no power on the brown wire where the mercury kill switch is. I disconnected the kill switch and checking had power and the motor started. An hour later the motor would not start and no power at the brown wire. After a little tinkering, I had power again and motor started. Yesterday no power at the brown wire to distributor. If I scratch my meter probe either on the brown wire connection or on the ground connection I hear a clicking noise like a switch opening and closing and the meter fluctuates. Maybe a short somewhere? I know my internal harness from control/battery is pretty bad. I have taped and used liquid insulation to cover bad areas. I know I need to replace this but wanted to get the boat running first. Any suggestions helpful.
Faztbullet
Re: 1974 115 switch box question
Sounds like trigger has went kaput...the clicking noise is coil firing into cap, pull wire from coil(not cap) and insert a spark wire for testing.
richardlee
Thanks for your suggestion. When I went out Sat afternoon, I had power on the distributor side of the switchbox and I started the motor several times throughout the afternoon. I will keep checking, though. I don't want a problem on the lake.
